Rust problems...
I have a few rust patches on the sills of mk4 valver
Is the best way to sort this to use fibreglass rather than filler? I want to do the 'donkey work' so the bodyshop can just spray it, save me a bit of cash. Any info on what would be best would be great as I'm going to take advantage of the bank holiday & do this tomorrow
Few pics so you can guage what I'm talkin about...
Rear arch - Sill
Front sill
Edited by Dub1
  • Views 846
find an auto welder any pay to have him cut the rust out and weld new bits on had both sides of the loon done for £110 and that was a lot worse on both the inner and outer sils
Wire brush bit in a drill & take back to shiney bare metal. If you make a hole itll need welding.
Treat with a rust cure.
Wire brush again.
Re-treat with rust cure.
Zinc primer time.
Now its ready to paint. Build up layers till its flat again.
Edited by Red Indian Mk3
