Debadging the rear
I want to get rid of the 'POLO' and 'GTi' off the rear. I heard the best way to do it is heat them up with a hairdryer, how long for though? And then use something to peel off the badges. I've heard people using bank cards, fishing wire or flossing string lol. Anything else? Whats best? I'm just scared of it leaving a mark on the boot, but obviously i'll give it a good wash and a t-cut if need be.
  • Views 1.6k
search function it, all methods work... not sure if mk5 rear badges are held on with pins or not though :? i think its only side strips on them that are.
you are right danny heat it up, credit card and peel it off ! just t-cut or use megs scratchx
no need for hairdryer mate...just get boiling water...not tooo boiling though...kettle will do fine.....
poor it over the badges and they will peel offf...
you will be left witht he black tar now to get rid of this get an old credit card....keep pouring the water over it and scrape it offf...only take 5 mins top..
then use polish after....make sure you do...
i did my polo and 1.4 badge in 15 mins first tym :)
no need for heat or hot water just get dental floss and use it like saw behind the badges
done all mine in about 15mins, but you obviously have to clean up the mess after you've done it :)
Edited by 888lewis888
do you just pour the water over the badges and then try and peel them off ?...or do you pour the water onto the badges and then use a credit card to "dislodge" the badges ?
I'm kinda confused
i find a good plastic filler applicator best
