Ebay White Mk3 Polo Warning
Been to have a quick look at the following polo thats currently on ebay....
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?Vie...E:X:RTQ:GB:1123
The underneath looked quite clean with no rust on the sills,just a small bit on the jacking point.What the advert doesn't mention is the fist sized hole in the battery tray :shock: When you look down at the battery from the engine bay you can see the drivers floormat :-(
Apparently he has had offers of £175 and £225 :shock:
Pettsy
  • Replies 12
  • Views 1.8k
battery tray rust is common on mk3's
mine leaks in, in heavy rain, so does dougs
can easily get it welded up
You have to take the dash out to weld the battery tray .
Cant really see the rust around your feet till you get the carpets out either .
I would stay away from it myself too to be honest ..
Could find somthing in better condition for the same cash ..
supose if the rust hole is the size of a fist haha
its is gash condition anyway
Or less if you look hard enough!!
fisting battery trays, oooh errr
rust in the battery tray? thats nothing, my old loon (before my last one) had no battery tray left! cost me all of nothing and an hour of my time to cut one out at the local scrappy and weld it in. if your scared of rust mate, never buy aircooled, you wouldnt get far :lol:
Yeah but this ain't about air cooled VW's.
This is about a mk3 Polo with a very rotton battery tray. The chances are, if the hole is the size of a fist its obviously been leeking for a few years. That means the floorpan/inner sill is probably fucked too.
Anyone can quickly weld in a "repair" but to do the job properly it is a dash out job.
Why buy a shitter when you have a wide choice of other Polo's to choose from?
Edited by breadman
aircooled : worth saving
1.0 mk3 : worth scrap value!
to those above doubting my assesment of the battery tray...i've had my fair share of mk3's and rusty battery trays, just thought i'd post a warning up incase anyone was thinking of bidding on it!
i did mine without removing the dash and nothing caught fire, although i did have a botlle of water to put out any potential fires! the only prob is that its a bit tricky getting into the tray area with the welding set. if theres some good metal around the hole you could even get away with riviting a plate over the hole then seal it up with seam sealer.
^^yep welded mine too... dash in, carpets in... no worries... 8-)
a repair job it may be, a work of art it is not, but the rain is not coming in... job done! :lol:
i welded mine with half a tube of silicone sealant and it never leaked in the 18months i owned it lol
Iff your going to to do the job you might aswell do it propperly .. :lol:
I do get a bit anal about things ..
Although i am going slightly pikey with my Loon ..
Bit or rust removal then some Por15 and then Glasfibre ..
