Removing front wings
urgent help needed!
right in the middle of removing the nearside front wing, removed all the bolts and screws but it still wont budge, it seems to be moving at the front near the headlight but not further up near the windscreen. it looks like it might be spot-welded to the chasis in which case i shall stop right now.
anyone have any ideas??
I've read before that its only bolted. Theres a bolt @ the very bottom of the wing @ the sill hidden under sealer. With all the bolts out @ the top in the engine bay that should be it ,although seam sealer would have been used in production. This can stick a panel on without the bolts when set.
Has yours got an arch liner? Might be worth removing this & having a good look with a lamp.
Right,
Its been a while since I've done it but I think I remember where all the bolts are.
One should be under the front indicator, then there will be the 3 obvious ones running along the top of the wing.
You need to remove the plastic arch liner and look into the wing towards the door. There are 3 bolts there, covered in sealer, I found using one of those small gas blowtorch things was the easiest way to metal the sealer. Theres one near the top, near the middle and near the bottom. Then there is one right at the bottom of the wing right on the sill part. Usually covered in sealer and shit as well, once you've removed that you will need to carefully pry it off. If it doesn't seem like its coming off heat up the sealer a bit more as thats what kept mine from coming off easily.
First time you do it, its a proper pain in the arse but after a few times its gets easier.
The hardest bit is the ones inside the wing as your vision is limited unless you can get the car up at eye level. Well thats what I found anyway.
lol try getting a wing off a polo thats 3 cars high at the scrappers FUN! heartagrams method is the best and the one i use!
Why would you wanna do that? :shock:
A new pattern wing from ECP/GSF is only about £30. Fuck climbing up piles of cars at breakers yards for a wing! Maybe for a set of O.E. fogs or other rare/expensive bits, but not for a wing.
Personally I try not to use breakers yards. Here in the South, the majority of 'em are unbelievably expensive and most won't let you near the cars anyway. The bits are all shelved and stacked up ready for sale.
