Rev counter stopped working
Apologies if this topic has been answered before. I did a search and could not find a specific answer.
Car is Mk3 GT squareback
Basically the Rev counter has suddenly stopped working. Worked fine before. I havnt looked at it yet, but wondering if anyone had a similar problem and if the solution is a simple one, or complex. I havnt touched the dash, so no wires should have come out the back. However, I have been fiddling with the battery in which case, could a blown fuse be the problem? The other guages work fine.
thanks
  • Views 876
First thing to check with anything electrical is the fuse. Use the owners handbook to locate the fuse number. After that it could be a bad connection or a dry joint on the pcb at the rear of the instruments.
-S
thanks
Could be a sign of the hall sender about to fail. The 3 wires that go into the dizzy. I think its the middle 1 that sends the signal for the rev counter
