Inner arch plastic can i trim??
hi i have mk4 polo and evrytime i hit bump the tyres catch the inner plastic in the arch
will it be fine if i trim some plastic off
thanks
  • Views 1k
anyone
I know a guy at a tyre place and he says the plastic will wear quicker than the tyre. Which is true, but you can trim some off to save some wearing time.
I've heard that if alot of the plastic is trimmed and because of the dirt from the road the arches will to rust is that true??
I had to trim some plastic but not much. I guess if you cut it alot it the inside of the arch will get sprayed in the wet but I don't know if it will rust
just jack up the car, take a wheel off and trim the plastic. Slap some black hammerite on as much of the metal as you can see, and it should help protect it if you chuck on a coat or two. It will rust slowly though, yes, if left untreated.
