Getting another key cut
I hope this is the right section for this. Basically I only have one key for my car which obviously means if i lose it I've got a problem. I was wondering how I would go about getting another one cut? I'm guessing its not as easy as just taking it to a key cutter place and getting them to do it?
Cheers,
Dan
  • Replies 13
  • Views 2.1k
You can go to VW to get a key cut and coded - expensive.
Get a key cut by a locksmith and coded by VW - not so expensive.
Get a key cut and cloned at a locksmith - Prob the cheapest. ( not sure if they clone them in the UK tho?)
We have had a few issues with non genuine keys but on the whole they are as good as the VW ones.
Cheers Matt
need to do this for a mk3 surely you can just get one cut?
I got one cut for a fiver! at a shoe repair place... ;)
mk3 don't have an immobiliser chip built into the key that has to be coded to the ECU though!
oh... :nod::oops:
Not all mk4's have an immobilisor key do they?
Thats right some of the early ones didnt have an immobiliser. A locksmith will have a reader that would say if its an immobilser key with a chip.
Matt
a mk3 key you can get cut anywhere that cuts keys.
But going from the sig pic its a Mk4
Matt
Matt
Yeah but mk3 keys were mentioned here in the thread as well.
Wouldnt just save the hassle and go to VW do it without hassle
if its a mk3 should be fine just getting it cut, if its a mk4 chances are it has a chip in it. Either way any decent key cutting place will be able to copy the chip- ask them before you get it cut... they have keys with red blocks in them, these contain a chip which they can imprint your chip onto (we have the technology!)
iv got a 6n cl, key has a chip in it, and iv had 2 keys cut at different places and they were able to copy the chips fine.
what year is it??
we can cut and code them now
after i pay 100 from vw :disgust:
dont try save money and buy one off ebay and try get it coded at vw because it wont work and they still charge you the coding cost of £50
