Removing bumpstrips?
Hi there could somebody tel me how to do this please, do you just pull them off? if so will they clip back on afterwards. Want to get them of to clean underneath
cheers :-)
  • Replies 8
  • Views 1.5k
If you've got a mk4 they'll come off once heated up but it leaves a layer of glue on the paintwork which you have to rub ALOT with something tough to remove it. best way to bring the strips off without leaving lots of the glue on is to use a hot kettle of water pour it over the rub strip and then have some1 dragging the strip away gently whilst your doing this, however for mk3/mk2/mk5's i dont think it's the same process. anyways hope this helps take your time and use some t-cut and polish after removing all the glue
Cheers for that mate, but forgot to say its on a mk3! The black platics ones, anyone know about these ones?
cheers
Easiest way is to get some warm water (not boiling hot as it could burn the paint and leave it looking blotchy). Then go buy something called a biscuit wheel (sometimes known as a fudge wheel or caramel wheel). Basically you put it on a drill and it removes glue from the paintwork without actually damaging it. Its kind of like a rubber disc thing thats light brown and smells of fudge.
You could spend hours and hours rubbing it off by hand or you could spend about £5 on one of these wheels and it'll take you about 5-6 minutes a side to do.
Halfords don't sell them, some motor factors do but your best of going somewhere that specialises in bodywork or paintwork as they will have them in stock.
Ah ok cheers for that mate, i need to get one of those for some glue i need to remove elsewhere. I dont actually want to fully remove the strips i just want to take them off so i can clean underneath because theres some moss in there! do they just pull off and clip back on?
FAQ :wink:
They will need to be taped back on with proper trim tape.
The bump strips are in 2 parts, one part is glued on to the body work and the outer bit clips to it.
I think the problem will be that in trying to unclip the outer part you'll end up pulling off the glued on part, or not be able to clip the outer bit back on properly.
One day I knocked the outer bit off my drivers door and it would not clip back on properly, I got so pissed of with it after a week that I took all the bump strips off completely. In doing so I uncovered damaged paint underneath, and ended up having to rub down and re-paint a pannel.
I recon you're better off digging the moss out with something like a tooth pick or plastic blade/spatula, it may seem like a painstaking way of doing the job but I think you will save time in the long run!
Edited by RAW
Ah cheers for the link to the faq didnt see that one! and cheers to raw may now think twice about taking them off to clean! I see you have my mate ad's old g40, stunning car :)
