headlights
I've got something on my headlights (was there when i bought them) but when the lights are on its like a glitter effect (only way i could describe it lol) some has come off in the corner and its definately on the outside becasue you can feel where some came off. i just wanted to know what i could use to get it off.
halfrauds reconmended tar remover and it never worked
tried T-Cut doesnt work
either does autosol
my dad tried thinners and it went dull (even though i told him not to) :angry: its polished out a bit but i can still notice it, dont know if anyone could. (he wants to use thinners on the whole lights becasue it did take it off but it will probs knack the lens with it being plastic, after all i did get told thinners will melt plastic)
any suggestions??
cheers
Edited by VeeDub9n
  • Views 1.6k
Sounds like it could be paint overspray if thinners took it off.
Could try 2000 grade wet n dry paper,wet of course. Test somewhere out of sight if poss.
What about one of those plastic scourers that you get for in the shower. I use one on the paint to remove bugs without scratching.
Thinners could dull the whole surface. Not sure if it would buff back up.
Youll just have to keep tryin a few things.
wet and dry sand paper has worked, but i need to spend more time to get it completely smooth.
but I've got another problem, one of my headlights has condensation in it (majority of the light but only the passenger side light). i left my lights on which got rid of most of it, so i used a hair dryer which pretty much sorted it out. But i went out later on tonight and it was back. Anyway of getting rid of the condensation for good??
cheers
Is the light cracked anywhere especially the joins. Are there any holes in it anywhere or bulb covers missing.
When one of mine condensated up i dried it out, then resealed the bond join with silicone sealer.
Some lights do have drain holes in the bottom to let water out. This of course lets damp air in.
Compare each light to each other to check for any missing parts
Theres a slight crack in the seal at the top of the light. Also my bonnet also doesnt quite fit properly on the same side, so I'm thinking water could of dripped off the bonnet and in the crack in the seal??
I've been told to wait until its dry and sunny and park it in the sunlight and it will dry it up, then re-seal it. But from the weather e've had lately it might be a while :smirk:
cheers
Yeah when the sun condensated mine up i removed the bulbs to help get some air in there. Then reseal when all the wet has gone
What are the chances of HID's meltinf the lenses of my FK projector lights (plastic lens)??
The drivers side lens is slightly thinner than normal (due to thinners :? ), dunno is this will affect it, just thought id give it a mention. It has ben flattened down with wet and dry.
cheers
cheers
Seriously, i'll not tell you again how cold they run! you've touched my headlights before when they'd been on for ages too.
Stop worrying and just buy the bits and lash them in!
