Can't Get a Decent Earth/Ground for my Sub
Hey guys,
As title and description says,
I have a brand new alternator and the wiring appears to be all connected up.
I also have a new battery.
Anyone have any ideas?
Rob
  • Views 1k
how is the amp earthed in the boot ? where to ? what with ? what amp ? what cable ?
:D
well I usually use a seat bolt or light bolt but neither are working just normal 8 gauge with ring and spade connectors running some cheap 4 channel amp I bought off someone on here. I have got it working before.
Do I have some dodgy wiring under the bonnet?
try connecting it directly to earth and poss on the battery as i reckon you may have shorted it and blown it ;)
If you've earthed it to a light bolt as you put it, I assume you scratched the paint off to create a proper earth?
Check condition of the cables too, is it definately going into protection mode because of bad earth, not into thermal protection mode?
I had a shitty 8AWG power cable once which had been stored tightly folded and it frayed some wiring inside the plastic which caused it to fail.
