G40 & Polo turbo chips
G40 K03 turbo chip #1 (K03 turbo, cam, G60 injectors, boost switch set at 6psi to replace full throttle switch on TB, 1.1 bar boost) - £50
G40 K03 turbo chip #2 (K03 turbo, cam, G60 injectors, 1.1 bar boost) - £50
G40 Fahrvernugen tuning chip for use with 65mm pulley - £20
G40 1341cc base map chip for use with G60 injectors - £30
G40 1341cc custom map chip (toothed belts, big valve head, cam, ported charger, 4-branch, G60 injectors) - £50
I think I might have an old Jabbasport chip somewhere too, will update this if/when I find it!
  • Views 412
I want the chip for 65mm pulley but I'm skint untill weekend. :-(
If you still have it by then ill take it. Is that price delivered?
D'oh. I wanted that too :-(
pm sent
Edited by coz_g40
