removing wiper
ok I've removed the actual wiper from the rear...that was the easy part...
after doing so i was left with a screw thing hanging out...guesing its connected to the motor which is inside the bootlid...
how would i remive this....
I've got a 6n2 polo by the way
cheers
  • Views 957
I'm not being funny or anything but OMG I litrally have no car experiance and this is all just common sence... open your boot and look to see any skrews if there arnt any (probobly is one) then just get your fingers round the edge and pop it away from the metal like you would a doorcard, there you just unskrew 2 more bolts and that is it.
then you need to put a blank plug like this in
okk....now I've taken the motor out that done....one if the wires is a real struggle tried everything..
heres what it looks like :
also i bought a 1 inch blank but too smalll could someone advise me on which one to use...size wise...
6n2 polo
cheers
someone hasnt eaten there weetabix! and if youve got the blank on you why not just see if it fits?! bit of silicon never hurt anyone.
trace the wire back see if ist actually connected anywhere via a block they usually are, tis quite streight forward. good luck though :thumbsup:
