Bumpstrips on doors
whats the best product for getting the glue off after taking the bump strips off
  • Replies 10
  • Views 1.8k
good bit of elbow grease and a hair dryer :-D
hair dryer and sticky stuff remover and a credit card - its a ballache!
You could use that method which will take you forever....
Or you could use my method that will take you all of 10-15mins....
This question was asked a few days ago. Do a search.
actually, thinners will remove it in one sweep of a rag. it doesnt damage paint either. just make sure you dont use loads and wear latex gloves
i have no problem gettin them off just with a towel.. (old one)
just rub.. some petrol assistance for stuborn parts..
my question is on the g40 arches edition.. how do you go about removing the strips on that?
that be one and the door is cool.. but what about the little bit attached to the front arch ?
have you actually done this?
the easiest way i came across was boil the kettle and pour along the top of the bumpstrips, may need to do it a few times.
i used 988 anticorit, a mate used it to remove the badges off his MGB.
just make sure that u havnt had a respray or u get bubbles in your paint
i realised that after, not knowing it had been resprayed before
Boiling water can damage paint in many ways. Best to use warm water out of the tap.
