AEE Metal Inlet
Needs to be a metal one so i can cut and shut it with my GT one :-)
Cheeeeers
  • Replies 12
  • Views 1.3k
Cheeeeers
Dont think they make an AEE with a metel inlet manifold, there plastic?
Apparently the SPI has a metal one?
Do the AEE and the ABU have the same head?
Sorry i thought you meant MPI, I'm unsure about the SPI's but i know the AEE and AEE have different port shapes???
one of the old GK/MH i dont bloody know , old polo engine has what seems to me the same base plate
cheers will look into that mate.
I think it would be far easier to make an adapter.
AEA/AEE/ABU doesn't share the bolt pattern with any other Polo
yeah I'm thinking either make a base plate or weld the holes on the inlet and redrill.
Hi I'm doing a similar conversion to what you're doing not getting any joy with the aee cylinder head so I'm retro fitting the 1.3 cylinder head that way everything bolts up as normal
Which 1.3 head?
you carnt use a GT head because of the compression apparently, which in theory would mean any mk3 head as they are all the same design bar the internals
the gt head wont fit on. combustion chambers are different. Aee is in the head, where as 1.3 is in the piston!!
but good luck trying.
My aee is mpi, everyone we've looked at has a plastic inlet on.
sorry to butt in like xx
No worries ema
Mines coming on good, just need a bloody car for it to go in :(
right back to the drawing board i had to suck it and see for myself yes 1300 head does not work so back on with the 1600 head and I'm going to get a cnc flange made up and attach it to the 1300 inlet manifold. hope the westher holds out 2morrow
