My Polo Is Being Scrapped :(
Yep, took it for an MOT today and failed on structural rust in the arch, right where the bend is on the fuel filler neck, i cant imagine a worst place for this sort of crap to happen, they quoted £200-£300 to weld it up due to them needing to remove the tank and shit :-(
Its just too much money for me to put into this car, so I'm stripping the valuable stuff off and gonna get it taken away :-( (PM Me For Any Parts)
I've put many many hours of love into it and after 2 years its gonna be hard to see it go :cry:
Edited by hypojam
  • Replies 16
  • Views 1.6k
See if you can bargain with them, say you will do all the manual work, taking off the tank and shizz if they just do the welding, see if they will take the price down a bit for you?
/\/\ Took the words out of my mouth, removing the fuel tank should be a piece of piss, taking away all the labour on their behalf.
ask mates mate... they might no someone who can weld. u can buy a welder cheaper than that! buya welder do the work yourself! :lol:
Yep i would give it a go myself but its in an absolutely awfull place, and we are not sure how far this rust goes thats the main problem :?
Even if the cost went down substantially its still more than i have to splash out, and my gearbox is on its last legs now too, so i really do think this is the end
Get some pictures of the situation up. There's quite a few proficient welders on here who might be able to lend a hand!
:( :( :( :( :( :cry:
Don't do it!
Edited by donnyburger
Thats a damn shame mate. :cry:
Yep i will try to take some photo's, buts it not an easy spot to get the camera to see...
Somehow looks less worse here lol
thats where mine went on the loon but it went on both sides i got both sides done for £110
its a bit of a trek for you to se the same fella as he's in barking but it dose give some hope.
my mot tester quoter £2-300 as well
Edited by brokenarrow
scrapping it isnt such a bad thing. i assume you are gonna keep the engine you've just done a top end rebuild on, and the other good bits. why try and scrape together a car thats had its best. mk2 breadvans in better shape are easily found for the same cost as the repairs you've been quoted.
i sold mine with a years ticket for 250 about a month ago.
mines gone there to a massive hole
I'm sure you can find some one who will give you a hand
just remove the tank urself it easy then
weld weld weld.
yeah I found a hole there in my mk2 yesterday, but its not being scrapped, but there is a fair bit of cutting and welding required to repair it properly
Oh man thats bollocks, If the tank was dropped I reckon it wouldn't be too bad to weld, I had the tank out on mine to work on the rear arches and made sure there wasn't anything too bad in that area. I actually had to do a far more tricky repair on the other side inner arch where I put my finger through.
While I had the tank out I treated it for rust and used gallons of waxoil underseal pus cavity wax in that area which tends to catch the road salt. As I say I personally wouldn't be put off with that, just find someone in your area who could weld it. Beware every single Mk2 is likely to be in the midst of having the same problem...
I hate the way garages just reel off a price almost encouraging folk to give up their car. I just thought fuck this I'm no mechanic but I'll go and learn to weld and get a mates rates thing going to get mechanics done.
Edited by MacColl
I can totally sympathise with you, Bluey is currently in my garage in lots of bits with a hole in exactly the same place :-( I've got a hole in the bottom of the sill and a hole where yours is, not quite as big by the looks of things but still.... took the tank out to investigate thinking i'll just need to waxoil behind it but no :crybaby: still it will have to get fixed as no way Bluey is getting scrapped! seems like its happening to a lot of us with mk2's of a similar age.
i hate having to scrap any car i've had. Like having a pet put down!! Learn to weld is my opinion. I'm not the worlds greatest welder either but i still managed to weld my exhaust and its holding better than i ever expected!
