wobbly HT leads
i got some new ht leads for the bready from gsf and they have like a big metal cage/case thingy on the ends that attach to the plugs and because of them the leads keep shaking loose of the plugs causing it to mis fire i have pushed them on as much as they go but it still happens any ideas how to make them more secure?
cheers
nath
  • Views 1.4k
bin them..serves you right for buying from GSF :lol: i cant imagine there is much you can do really. have you ushed them till they go click click click?
Edited by supercharged spaniel
Unscrew the little connector bit on top of the spark plugs so you're left with a thread (you'll need pliers or something)
thats the only explanation i can think of, used gsf ones for years and had no problems. the plugs come with the little bits screwed on them they need them on for some types of leads and not for others (like gsf ones) you do have to push them on quite hard until they click tho. If you need a hand welcome to pop round and compare with mine.
well the new alternator is going on tomorrow so i will make sure they are on properly i didnt push them on too hard through fear of breaking them lol if that doesnt work i will let you know what happens...
Edited by mk3_nath
