Repair or Replace?
Sorry to ask questions about bump strips!!! I have searched for help but cant find any for this. I have removed the bump strips on my 6n Polo 16v and the paint under the bump strips is crap so I either need to get a respray or put new ones on but the laquer has peeled back slightly so I would need bigger bump strips!
Any ideas if 6n2 or even mk5 strips have clips or are stick on?would you recommend getting the dodgy paint touched up or getting new bigger bump strips to cover it up?
t cut it
t cut it
yeah forgot to say on the passenger sid there is primer where the strip used to be and the laquer is around the bump strip and has a deifned line where the levels are different. will try and post pics 2moro.
sure 6n2 strips are clip in dude. not sure if u could take the clips off. would need to colour code strips so mayb get doors blown in.
david.
cheers for the advice peeps, car is going in to get rear arches cut out and new ones welded in and painted as the old arches are shot, so I will find out how much extra it will be.
makes sence.. they will have to blow doors in anyways to get a colour match on paint so shouldnt be too much more.
