steering wheel
tracking and camber are correct on my 6n, but my steering wheel is out of alignment, so i need to move the wheel around, but i need to kno if its on a spline so can be moved a few notches or if its the hexagonal nut which then will put it out the oposite way.
if its a hexagonal, will replacing the wheel with a hub and racing wheel be able to put the wheel stright?
Edited by polo-shuff6n
  • Views 934
answered :p
splined fitment so yeah undo and adjust and do up again :)
but a racing wheel would look much better ;)
you'll knock the auto off indicators out though
when the car is tracked they should secure the wheel straight and adjust the tracking with it in that position ;)
if you put the wheel straight then remove the key so the steering lock comes on it should lock with the wheel pretty much straight, if it isn't then the wheel is out of line, if it is then they've tracked it wrongly. take it back and get them to sort it!
if it's really bad you might have an un even lock (turning circle better one way than the other). they do a four wheel laser track round here with a steering wheel clamp to get it bob on.
