worth a try here, vr6 engine,box,loom,ecu subframe...
well heres the pics, its detatched from the car still on subframe. i can split if intrest but alltogether we have engine 114k no inlet manifold, gearbox, cable change system, clutch pedal box, all coolant hoses, wiring looms, ecu, header tank, power steering rack pump and res, subframe with wishbones, fuse box, down pipe and cat.
all the above for £550 ono
I'm just outside cardiff
Edited by oldrope
  • Views 497
MMMMMMMMMMMMMM just finished putting a VR6 lump in a 1.9D Golf estate so I'm very interested in the inlet, cams and chip if you would sell seperate if so how much you looking for.!!
Posting picture up soon of the beast!!!
Think i need to come to your garage and see that beast :-D :p
hmmm, you wanna go to his garage and see his beast.....
:D
I'm breaking this now if anybody wants any bits
took the cam cover off to check if the cams are actually schrick, and they aint!!! so the guy i had it off was a total nob jockey. also the so called "chip" is just the controll unit for the schrick variable inlet manifold. neva ind, may still make my money back.
updated
hey do you have the head, would it fit on a h reg polo 1.0?mines been cross threaded by the spark plug?thanks
U GOT JOKES
