How to fix thease problems
well there is a few stupid little problems i need to fix and was wondering how can i fix them the cheapist way possible??
problems are:...
1] My boot lock doesnt turn with my key so i think its totaly broke...
where can i get a lock & key off from or of the internet???
2] My drives chair doesnt fold foward so people can get in the back..??
What could the problem be...
3]my driver side electric window doesnt work / go down or up...??
What could i do or get to fix it ..
  • Views 910
1 Probably a detached mechanism. You need to remove the tailgate inner cover
2 Broken cable. Try a search theres a guide on here somewhere
3 Check the fuses
Edited by Red Indian Mk3
1: probably crudded up, try spraying some wd40 into the lock then wiggle key. its worth a try before you got and dismantle your boot
3: the regulator has probably broken so the previous owner has disconnected the switch to stop anyone from opening it, at which point the window would fall into the door
