Dimensions
Hiii :-D
Does anyone know the dimensions for a mk1-mk3 Polo??
Thanks In Advancee =]
  • Views 4.2k
Only ones I can find on my bookshelf are:
Mk1 Derby
Length: 3835mm
Width: 1557mm
Height: 1351mm
Wheelbase: 2334mm
Front track: 1295mm
Rear track: 1313mm
Min ground clearance: 97mm
Kerb weight: 700kg
Max payload: 430kg
Max gross weight: 1130kg
Permissable axle loads
- front: 550kg
- rear: 610kg
Mk2
Overall length
- Polo: 3655mm
- Polo Classic: 3975mm
Overall width
- Polo and classic: 1580mm
- Polo coupe: 1570mm
Overall height
- Polo: 1355mm
- Polo classic: 1355mm
Wheelbase: 2335mm
Front track:
- Polo/classic: 1305mm
- Polo coupe: 1320mm
Rear track:
- Polo/classic: 1330mm
- Polo Coupe: 1345mm
Min ground clearance: 125mm
Turning circle: 10.3m
Kerb weights
- 1.05l: 700kg
- 1.1l: 710kg
- 1.3l 720kg
All from Pocket Mechanic manuals by Peter Russek
Thanks :D
A thats a big step towards me getting a project car [=
  • 3 years later...
is the front track the same as kingpin c/c ?
trying to work out the ackerman angle for mk3 polo. so can anyone shed somelight on this?
using the trsck width above I'm getinh aprox 15 degrees for ackermena angle.. How accurate should the angle be.
