Complete GT Engine
Polo GT engine for sale with every thing needed for a conversion inc:
Engine + gearbox 117000 miles (Just had new head gasket, plugs, oil and oil filter)
Inlet manifold
Radiator
Throttle body
Standard Air box
Airflow Meter
ECU (Got both standard and performance chips)
Wiring loom
GT Clocks
The only thing that i don't have is a exhaust manifold
Worked and run perfect before i took it out of my gt
£350 ono
Any questions please ask
Edited by VWbreadvan
  • Replies 19
any one interested i'm open to offers
the price is a little over priced i think, you could get a full gt for less than £350
just my advice if it isnt needed then please ask to have my post removed :D
thanks for the advice wasn't sure how much they went for will reconsider it
cheers
included:
Inlet manifold
Radiator
Throttle body
Standard Air box
Airflow Meter
Wiring loom
GT Clocks
Fuel Pump
Worked and run perfect before i took it out of my gt and pulled really well
The reason i'm selling i've just got a G40 engine
£290
I'm open to offers
what engine are you taking out of breadvan to fit the g40 lump, as may be intrested
i don't have a breadvan any more. i got a gt coupe that i've just put a g40 engine in to thats why my gt engine is for sale. if you interested your welcome to have a look at the engine
Hi there just out of interest for a mate because he is interested in the engine how comes it had a new head gasket.
jonny
Dont suppose you could arrange to send it on a pallet or something could you??
thanks but was really after a 1.3 spi just thought it was worth a chance as also in bolton,
jonny
It has done over 100,000 miles so the head gaskets needed changing, was mixing oil and water but all works fine now. The cylinder head is in good condition it didn't overheat so its not warped.
when i did the head gasket i also did the inlet gasket for good measure
thanks
its possible but i'm guessing it will be very expensive
hey will this just slot into a mk2 breadvan once a exhaust manifold hunted down for it. if so interested. cheers
Edited by dan113
Yeh it'll go straight in.
Where you from in Bolton VWBredvan? Never seen you dont think, theres a few of us into the old skoool VAG metal.
Joe
thanks. will i need anything else for this, drive shafts or anything. cheers
hi newbie here the oil pump packed up on my gt coupe so was just wondering if you would be intrested in selling the block and head on there own without the aux bits if so how much let me no thanks sam
hi m8 newbie here was just wondering if u would be intrsted in selling just the gt engine
hi mate in what condition is the gearbox?? would you be willing to sell seperatly????
would you sell the ECU, Inlet manifold, Throttle body etc seperate? Cheers Russell
