D.I.Y. bumper smoothing??
As above has anyone done a guide on smoothing bumpers, techniques they used and a picture guide taking you through all the steps??
  • Replies 14
  • Views 2.1k
have you asked a local body shop for a guide on smoothing body parts ?
no but tzrawling through snippets of what other people have done i think i can do it!
i cant see it being that hard to do you self like but, sanding down and painting could be a bit tricky !
theres a few ways to smoothing, you can plastic weld new plastic over the holes you wish to get rid of (the plastic must be the same type) basically you just need a big ass soldering iron to melt the plastic together, then sand smooth and fill any dips etc with body filler.
for small areas like go faster stripe recesses you can get away with using plastic filler on its own. it all depends what you want to do.
This would be a good idea for people that have actually smoothed bumpers and panel parts from some of the project threads to chip in and give advice and guides to doing this?
whats to explain? its not rocket science, you get a bumper, you fill or modify the bits you want to change, you prep it, paint it, fit it and decide you dont like it, so remove it and mod it some more!
Well we're not all mechanically gifted I've never dealt with re-sprays or smoothing so I was just asking for help
But it is exactley how he said!
Its a trial and error thing, if your not confident then dont do it!
Is that you in your avatar pic?
No it's Will from the inbetweeners programme on E4.
Thanks that was just what i was after
wow jon thats oen great guide youve made/found! definatly something I'm gan try on a spare 8v bumper :p
i did mine its not hard i did mine plastic welding - not very tidy cause i did it
then i fibre glassed it and then skim of filler !! seems to worked but did take some time !!!
Bumper smoothing with fibre glass
someone else wrote it! i can't take any credit for it! it is a good guide though, far better than i could have explained it
