mk3 foglight projector unit - driver's side OEM
I have a (I believe) mk2 Golf foglight projector unit which (I believe) fits the mk3 OEM lenses. I also believe these are discontinued from VW.
Here is a picture of it (on the right) next to a proper mk3 unit (on the left) so you can decide for yourself:
The differences are:
-Only one adjuster arm, but you can see the lower mk3 one isn't used.
-Wiring connector in slightly different location. This may cause minor bumper clearance issues with the plug connected but I'm sure you can get round that!
There is a bulb included - I haven't tested it. Also included is an intact rubber seal for where it slots into the lense. The only thing missing is the adjuster screw thread that will pop into the hole on the arm - should be pence from a scrap yard.
£10 posted? Knock £2 off that if you want to collect from near-central Birmingham.
  • Views 318
Bump!
Bump.. offers
Anyone? Make me an offer...
C'mon these are discontinued! (I think). A pair of mk3 foglights can go for £100 on here, and this is er 1/4 of the way there lol. I already have a whole spare mk3 foglight for this side so I don't need two. Nobody wants?
