Interior Ceiling upolstery, 6n2 Mk5
Finally got all my new stuff sorted for my polo 6n2 and now the upolstery on the drivers side passenger window is sagging so i can see it from outside the car.
My bros a VW mechanic and says it lost its shape which is obv
does any one know of getting it back in shape?
or may be I should glue I dont know
any help would be appreciated
  • Views 1k
Hi
I've got the same problem with my 6n2 polo. A garage glued it up for me but it came down again after a couple of weeks. I have taped it up now... doesn't look ideal in my opinion but nobody has noticed it. Looks loads better than when it was hanging down!!!
Just used normal cellotape, you can only notice it when the sun is shinning on it as its shiny.
If you find a better way of keeping it up let me know... don't really want to have to pay £180 for a new one which I was quoted from VW without being fitted??!!!
Hi
going to try and glue it now gona hold it in position with a wooden pole see how this goes
I used PVA (only glue I had at hand) put a strip of wood parallel with the window and the were the upolstery was peeling and then secured it with a wooden pole wedge between and the seat (covered my seat with a blanket to protect) put loads of glue on it before i did left it 24 hours and now its stuck hard will tell you if it peels again
