1997 Polo 1.4 CL Central Locking System/Alarm And Window Modulator!
Hi all
Just joined up, seems a good place.
I have a 1997 Polo 1.4 CL in green :D
I've come to fit an alarm, and sucessfully connected all parts, apart from the Central Locking System.
Being a VW, it uses air compression, which makes it a little more awkard than any other system!
The basic problem is establishing how the alarm central locking control works in conjunction to the cars central locking system. I'll attach some pictures, and hopefully someone with a little more experience can aid us! Can anyone make sense of the 'common line'?
As i said, the rest is connected (the relays were a little problematic..but we managed to wire them in), so this is the only part holding us back.
Thankyou for looking, and i welcome your responses!
Actual Alarm System: (part is relevant to the central locking system)
Alarm Automatic Windows: (having problems with this)
Alarm Central Locking Diagram: (the picture at the bottom is the relevant one-ignore the other 3 above)
Polo Central Locking System: (diagram from the Haynes Manual- ISBN 1 85960 598 2)
Polo Electric Window System: (diagram from the Haynes Manual- ISBN 1 85960 598 2)
For Haynes Manual: - index of colour codes and items
1) Battery
5) Fuse/relay box
109) LH front central locking actuator
110) Central locking control unit and pump
111) Driver's central locking switch
112) Passenger's central locking actuator
Ws = White
Sw = Black
Ro = Red
Br = Brown
Gn = Green
Bl = Blue
Gr = Grey
Li = Lilac
Ge = Yellow
Thanks again
Matt
Edited by mattsa21
  • Views 4.7k
Hi again.
Right, got the central locking working! Its pretty good.
We just had to connect a few things in the boot.
However, we can't work out the window modulator! Anyone any ideas on how to connect that successfully? The idea is that the windows rise when the alarm in activated.
Thanks again
Matt
have you phoned hawk to see what they say ? they are normally helpful
