6n grill
does the 6n grill just clip in or have i got to take off that plate above the rad in the bay to get at it? could wel be a stupid question lol :p
  • Views 825
f you lok between the grille and the plastic panel behind it you will see small clip things pull the grille out a touch and push a flat head screwdriver down onto the small clips and it shoudl pop out, there are 3 at teh topand one on the bottom you access when you have the top ones out iirc.
cheers brother, il av a look now :D
