6n2 Roof Strips
Just thought about getting 6n2 roof strips as I'll be replacing the standard 6n Window with a 6n2 one and go ahead with the roof strip mod! :-D
Does anyone know of the part number for it?
  • Views 882
if you call GSF they will tell you this or even if you order direct form the main stealers they should be able to understand what you want.
and good luck with it, its somehting i want to do but I'm not sure i can on a 5 door :(
:shock: Woah Lucky i posted before i ordered a 6n2 window! I have a 5 door aswell. Isn't it the same structure/frame at the front as a three door?
Edited by polo_dude
i think so, its the strip lenght I'm not 100% sure on.
So i haven't dived into it incase it is wrong, as I've only ever seen it done on a 3 door, ok so maybe you could cut the strips down if they are abit long but i was abit worried of them being abit short... hmm anyone shed some light on this?
Edited by POLOMON
