13x7 0 offset
hi,
I'm looking at some weller wheels ,size is 13x7 offset is 0, i was wondering if anybody would be able to advise me on wheater or not 0 offset would stick too far or rub on a 85'coupe lowered 60/60. i have checked out the faq bit and 0 offset i figured might not be suitable , am i right or wrong?
I'm also considering a set with a et +19 or et -12
Any help is much appriciated :-D
  • Replies 8
  • Views 1.7k
Will poke a little on the rear. The fronts will poke rather too much i should imagine.
Too much, ET15 is border line on the front of a Mk3 at least.
Thanks for that il let them go then, what about et 19 on a mk2 ?
I don't think it should make a difference. The suspension setup is exactly the same and I'd imagine the width of the wings isn't any different.
ET19 should be nearly perfect on a mk2/3 (at the front).
Can't see you going wrong with ET19 either, sure my friend runs ET20 13x7's and they are fine. Only Wellers I have seen have been stupidly wide, will be nice to see some that fit well.
Cool, just got abit more info about the + 19 offset set , they are 13x5.5 et+19 with a back depth of 97mm.
If i where to get these what tyre could i fit without it looking ballonish?
I've noticed alot of dudes fit wider wheels to the rear , is this just a image issue or a technical one?
Dmo
175/50/13
A lot of people just prefer the look of staggard wheels. Theres no real reason to do it.
Dmo
I've got 13x7 ET19 wheels on the front and 13x8 ET6 on the rear and they're pretty much perfect fit.
I doubt you'd have any trouble with 13x7 ET0 with 165/55 13s though.
