ENGINE PAINTING
as above really I'm going to be painting my enigne soon and want to know what type or is there a specific paint for it
any help would be most greatful thanks chaps and lasses yoyo
  • Replies 21
  • Views 3k
Depends which parts your doing, but that brake caliper paint should withstand the heat, & is available in various colours
frost do most oem colours mate, but hammerite I've herad is used aswell as that has a high melting/burning point.
buy some engine laquer from frosts
I'm going to be painting the hole engine block gearbox starter and alternator motor, I'm going to get it done properly from a bodshop but i want to make sure which type to get,
so brake caliper paint, hammerite and frosts?? whats that or who lol??
hammerite paints dont cum in satin do they or matt??
cheers for the helps peeps yo
Edited by mk1nuts
I would have said Hammerite or Radiator paint.
Check in B&Q or Wickes to see what Hammerite types they have, I think even Halfrauds have different types of Hammerite paint (satin etc).
ooo okay matey thanks very much i'll go n have a scout for some
as it will be going through a spray gun i need to thin it down but wont thinners fuk hammerite paint
just heard it does but might be rong, i am normanly lol
thanks mate
you can get matte balck hammerite, but on equestion.. why pay a body shop to do something you can do with a paint brush! :?
ooo okay. o cuz i want i to be foobaring perfect and havin som smoothing done to but thinking about it now you.ve said it i'd prob do a better job at it too lol
so what paint could i get in satin or matt finish that will with stand the heat of the engine??
thanks matey
well all i can think of is satin black hammerite.. or maybe try your local paint mixers for VHT paint with matting agent in or somehting so it goes satin/matte, but always remember the paint will only be as smooth as the metal underneath...
VHT paint right i'll see if i can find some of that but yer all else fail's i'll have to go for satin hammerite
and yer i now dude i might take a bit of sand paper to it to give it a bit of a better finish lol
cheers fela yo
i used the halfords gloss paint from a tin
make sure the block is super clean to get a good finish and so it stick on well
mine
man that is uber sexy! wish i had the time to do something like that, i think id just wrip it out paint teh lot then shove it back in :lol:
looks good that
think am guna do that to ma new un when i put it in....
whats the best way of blocking the exhaust ports n all the other duberyferkins
toilet roll is all I've used in the past.. but you stay around the gasket faces anwayz so you wont get paint in them :p
cheers duck
Engine Enamel from Frosts:
engine enamel on frost.co.uk
I wouldn't have thought Hammerite would last all that long really, it's more designed for painting garden gates etc...
agree with hayesey, use engine enamel for an engine¬!!!
hammerite is what i had on my old mini turbo and it lasted uww about 4 months :lol: just melted and ran off :p on the back that is front was perfect (ish) but frosts BMC enamel is what i have on now and WOW! its tough stuff!
Hammerite is fine for rocker covers. I've painted my head with halfords matte/satin paint, to be honest its more like a dull gloss than anything, so I'm a bit annoyed. Perhaps the finish will change when it heats up, I'm not sure as I've not had the thing running. My inlet is done with hammerite and the zorst manni with the halfords paint.
I'd say dedicated high temp paint for the really hot bits, but hammerite will be ok for the rocker and inlet side of things.
hmm, enamel paint it is then!
if u want a matt black finish just get some bbq paint from b&q that stuff will easily be up for the job
