dent removal
as u can see from the pic below my sis a good few months ago decided to put a dent in the drivers door and the front panel
how would i go about removing this?
Edited by mtbtom90
  • Views 1k
If I were you I'd be down the scrapyard buying a new wing and door. Will probably cost you about £30 I'd imagine.
Repairing it seems like a waste of time to me cause the wing looks a bit scabby anyway.
Front panel... I'd beat most of it out with a hammer then probably paint it black to take the attention away. Maybe filler/fibreglass to rebuild the shape but it would most likely disintegrate with stone chips?
For the door, easiest is probably a replacement door, same for the wing that looks dented?
Shouldn't cost a lot, just be time consuming!
the wing???????????
all of it does at the moment
