removing mk3 wing
hey,
I've tried searching but couldnt find anything,
how many bolts hold on a mk3 wing and where are they please?
(obviously the 3 along the top under the bonnet)
cheers
adam
- there's four or five of them on the top
- one screw holding the front to the front panel
- one bolt holding the bottom to the sill
- three bolts inside the wheel arch at the back holding the back to the car body: a bitch to get to and covered in sealer you'll have to pick off first
I think that's it...
cool man thanks for the quick reply...
oh do i have to remove the arch liner?
Edited by afleeds
Yep, or you won't be able to access the ones that run up the back
thanks guys appreciate it...
Dont forget to remove the screw on the aerial as it'll help keep it on and you dont want to snap the super trendy mk3 aerial lol. Just the bolts along the top, one right below the indicator (holding it to the front panel, a spanner is the only thing that will fit on it / unless the bumper is off), the several on the arch liner, then when the arch liner is off peak your head up in (along with a light) and look up towards where the door is bolted in, you'll see 2 bolts in there (a ratchet works best here).
You'll need a spanner, a screwdriver and some dry weather. Sorry but I cant remember the sizes (just 10mm for the ratchet socket). Good luck, its an easy task but. Chris
