replacing rear window 6n.
i'm going to be buying a smoothed boot for a 6n but it has no window in it, i was going to swap the window from my existing boot.
anyone know how to do it? or would it be easier just to buy a new one or get a pro to do it?
cheers.
  • Views 991
it is not an easy job to get a rear window out.
get a pro to do it. if its anything like the windscreen, getting it out without breaking it would be a major challenge, had my windscreen replaced recently and the fitters had a lot of trouble getting it out, they said the 6N is a bitch of a job, i'd assume the rear window is similar, hope this helps:D
The rear window for the 6n is what they call in the trade 'encapsulated glass' it means that the rubber seal comes moulded as part of the glass.
Normally when windows are changed the seal is butchered, glass pops out fine and then they just fit a new seal.
However this cannot be done for the 6n or the 6n2. You need a professional to do it, to make sure he gets the glass out with extra care not to damage the seal, it can be done, but most places don’t like doing it without a good old moan!!!!
Make sure it’s not a cowboy, just ask the guy about what I just said and see what he says, if he doesn’t know what you’re talking about then find someone else.
Expect to pay anything from £40 - £100
cheers, ill have a ring round and get some quotes.
