weight of a std g40?
just to end a debate
cheers
  • Replies 13
  • Views 2.7k
830kg apparently.
Plus (soz to highjack) but is a G40 lighter than an R5 Gt Turbo phase 2? And proof if anyone can find it regardless whether it is lighter or not :D
There was a thread on this (the G40 vs R5) ages ago. I do believe the G40 is 830kg and the R5 GTT was 845kg, but I'm afraid I can't prove it!
nice one mate, i'll get my search on :D
Just found this - 1992 1272cc Polo G40 - 113 Bhp / 770Kg ~= 150 Bhp/Ton
surposely more than the figures given from wikapida for the R5 phase II 138 bhp per ton at approx 850kg.
I've just found written on an old snotty tissue that the polo weighs 203kg. Sadly seeing it written down doesn't make it true; I've had a fairly stock G40 on proper longacre cornerweight scales and it came in at 831kg.
Weighed my '85 CS a couple of days ago - 727kgs. A MK2 G40 may only be 50kgs heavier,but no way a factory facelift model.
I'm sure my g40 handbook states 830kgs for a g40. isnt that heavier than the other models?
Edited by supercharged spaniel
780kgs for GT etc. I believe. Not sure where the extra 50kgs comes from...charger/pipework etc. doesn't weigh that much.
Edited by Tav
must be all that money you have to carry around to fix it :D
Every G40 I've known has been the better runner than any GT, that's for sure. Just happens to be when some of the specific parts go a little wrong it gets pricey :lol:
i think av poured about 4 grand into the GT so far haha, so am in no position to talk really :lol:
I think its 780ish kg for base models, GTs are 800 iirc.
GTs weigh more than base models because of a larger diameter exhaust, extra bits under the bonnet and the rear arb...
G40s obviously weigh more due to charger and pipework along with a larger again exhaust.
Plus, coupes are a bit heavier than squares.
I wonder what the weight of a mk3 burner is?
