is this an MOT FALIURE???
just been changing my fuel filter and found this???
  • Replies 16
  • Views 1.7k
Yes.
thats a defo YES FAIL!
how the hell did it get through the last mot?
i really dunno mate
how much u rekun to repair??
WOW! thats why you shoudl clean your sills liek me, so you can see rust forming :p :lol:
its wierd cuz the car is pefect from suface rust everywer on the car no dents or anything but its too good to be ture eh lol
get the filler out and touch it up with some red paint....you never know, you might get through it. worked for my dads mk3 golf lol¬
Made me worry so had to go outside and check mine, looks fine though. It's an MOT failure, but shouldn't be too much of a job to sort and it's out of sight so repair shouldn't be difficult.
i got quoted £75 to get one sill welded if that helps
someones been using a jack like a idiot by the looks of it
need a big plate seam welded in or a new sill for sure
mot testers cannot remove parts from the vehicle
in some cases you can put tape(yes tape) over rust holes and they carnt be failed as they cannot see underneath but that is quite a big hole you have
if you want it welded on the cheap, let me know, as I've a mate who'd probably sort you out fairly cheaply
definate fail..
mot tester basically has a prong, they go down both sills tapping it for rust patches so filler might not work, just get a patch welded in place and paint
My mates mk4 rusted in EXACTLY the same place...
He failed the MOT as it is within the 10cm radius of the seatbelt mounting iirc...
ALTHOUGH - all is not lost - someone can either cut / grind that back to metal - weld over a plate and add some new underseal for it to pass...
My mate was charged about £200 for the MOT including the welding in the end.
I know it not good news - but at least it is fixable...
Dave
Thats the same problem as my mk3..... but I've been attacking it with an angle grinder since!! Gotta have a bit of fun!! Cut it out, get a plate welded in and a bit of filler to smooth it, some metal primer (cant remember the name, but it prevents rust), and a touch of paint then sorted....
