Buffering Machine
could someone please advise me on what buffering machine to buy...
thanks
  • Replies 11
  • Views 1.7k
Megs G220 :smile:
or a porter cable - or a udm
Never used one, never seen one but when ever I here of people using them Megs comes up alot in conversation.
Simon
AlexC on edition 38 is hopefully sorting a group buy on the G220 which is what I'm waiting for
apparently the porter cable is meant to be the dogs danglies, however if used incorrectly could do more damage than good??
yeah you risk doing damage using any machine polisher i have 2 which both work well and can be picked up for around £50 from a decent bodyshop suppliers :)
just make sure you get some decent compounding heads :)
i know I'm probably gonna sound really stupid, but what is the benefit of having a machine polisher over doing it by hand???
PCs - Megs, Porter Cable, UDM all arent machine polishers they have a random motion. Its like polishing by hand but 100x a minute!!!!
machines are used more to cut the paint slightly where as polish and wax should be put on by hand anyway ;)
I've never used machines, but i always thought they was for applying polishes and waxes??
so basically its like using t-cut, or do you use it with t-cut etc?
well to start with it's used to finish fresh paint after it's been flatted to get rid of any texture using something like G3
then you change to a soft compounding head to remove swirl marks using G10
then you would hand polish with blacktop or simaler to put some protection on :)
http://www.farecla.com/automotive.asp?id=6...otive&set=1
shows you the process and how to use it :)
