Removing 6n doorcard
Hi, I need to remove the front passenger doorcard on a 1.4 CL with electric windows, can anyone tell me where the fixings are?
Rob
Fixings are dotted around the door card. The actual electrics aren't touched as they simply slot over the door card when it's in. Here as a couple of pics of the clips. They just pop off.
pop off the door handle cover 2 posi screws inside there, remove mirror internal cover, unscrew lock pin and remove, pry bar around edge of doorcard and pop off clips then unplug electric mirror adjuster wiring
Cheers Lads! Great help having the pics, thanks for taking the time to reply.
Regards
Rob
