bhp of a G40
settling an arguement with a friend, wikipedia says 113, but looking at the rolling road day all the g40's are around 140. so whats the answer?
cheers
  • Views 1.5k
Standard they are 113bhp
113bhp as standard.... all the other ones you would have seen would have been modded to acheive that power.
martin
cheers i was right and settled that arguement. thanks alot
quoted bhp is 113bhp
but my totally standard (with catalyst etc etc) made 123bhp when rolling roaded, so vw ar conservative with their claims
Or the rolling road was optimistic? VW state the correct 113bhp output, why would any manufacturer be conservative? However as with all engines there are bound to be some that produce a little more and some a little less due to production tolerences.
Rolling roads results should only be used as a guide. Results can vary from day to day and operator to operator using the same rolling road, let alone a different rolling road.
I agree that all dyno results vary, but that's not the whole story here. I also think that Aldon Automotive aren't particularly optimistic - lots of newer standard cars seem to make stock power there.
Manufacturers always are conservative with their power output these days for obvious reasons - you'd have them by the short and curlys if your new 150bhp car only made 145bhp, so they tend to quote absolute worst-case. At least 5% variation between engines wouldn't seem unreasonable on older engine designs. Then factor in that the power figures quoted are for new/low mileage motors. Get a car that's loosened up a bit, and you can find another few horses. 120-125bhp for a standard G40 that's been well run-in and makes good compression seems entirely feasible to me.
