mpg of g40?
i was thinking of sticking a g40 into my mk1 for something different, just wondering what mpg is likely from a g40. and how hard are they to find :D
also how much power can you get from one?
  • Replies 11
  • Views 1.6k
Power wise if you do a turbo conversion then you can get over 200hp from it I've got no idea on mpg though
a standard g40 is 113bph shoot me if I'm wrong... so around that to 130-140ish is quite possible.
Edited by tommyisthechamp
I think he's specifically after mpg figures over bhp. This conversion requires cutting of the bodyshell iirc,and as a MK1 version,they're around 15% percent lighter in weight so economy should be better than standard as long as sensible gearing is kept. I have no knowledge of G40 economy figures. Stick 175x50x13's on and the mpg will suffer - as it will do if you have an aggressive driving style.
i meant in a mk1 golf (:o sacrilege :D), well i was also wondering what power would be achievable. Currently its a 1.6 gti.
I dont really drive aggresively although i may have to have abit of a punt every now and again if i did the conversion,
not that hard to put into a mk1 goof i thought? need a bit of improv with one of the mounts but not too hard. Depending on what you want to do you could blast an eaton m45 charger or uprate internals, cam etc and get potentially up to 160bhp give or take? Thatd be fun in a mk1 :) And they're pretty rare but they come up on here every so often.
Id have thought you'd be better off starting with a small-block model. Your GTi would take a 1.8 16v,so why bother putting an engine in that is barely any more powerful than the lovely free-revving 1.6 tall block already in it? You can use bike carbs,40's,45's,K-Jet-i.. I'm selling a 1.8 16v this week,but i dont sell on here. The G40 MK1 Golf conversion has been done,more than once,but i dunno why.
i got about 20ish mpg out of my g40 but it wasnt exactly your everday g40 engine (was ex cup car motor and custom eaton charger etc)
so id say 30mpgish but maybe a bit less cos the golf is heavier.
A standard car will manage ~40mpg if you drive with a light foot, on long journeys at constant speed and everything is in good working order. As soon as you start increasing the power though mpg will suffer. Doubt it'd be any worse than your 1.6 and there is plenty of scope for more power/torque from the G40 engine.
Only real problem is finding one that's worth putting into your Golf. Many are getting a bit long in the tooth and have mileages above 150k...at this point you are looking at potentially having the rebuild the engine which isn't the cheapest of hobbies. If I were you I'd just buy a nice example of a G40 and keep the Golf as it is.
As said in the first post if you go for the trubo conversion route you are looking at over 200bhp (just) and you will need a remap for this but you could get a ecu with switchable settings (emerald i think it is) where you can switch bewteen a setting where you get more mpg and one where you can go round a track etc
Yeah you could do all that...if you had a spare £2k-3k burning a hole in your pocket...kind of defeats the goal of fuel saving.
Well there you go I've said he didnt say what the budget was :lol:
Plus all the time that that work is being done the cars not running so its saveing fuel
Edited by kerrgreg
