Battery Tray Renewal
Need to replace my mk3 coop battery tray.
I know I should get it welded up, but I need to do it on the cheap, and I don't have a welder.
I was wondering if anybody knows of a reason why I can't simply pop-rivet a new panel in place?
  • Replies 10
  • Views 1.7k
Mainly down to the strength needed. If it's only a small hole, I suppose you could. Make sure you've got all the rust out and the metal treatted first, and seal it well afterwards.
Thanks, man. Do you mean the strength needed to support the battery? Or does the panel contribute much to the overall structure of the car?
its been done a million times before lol
clean it up well use some sealer under the edges and plenty of rivets...then seal it up good, should be fine
Edited by steveo3002
its been a million times before lol
I did search! :cry:
Thanks guys, I reckon that's what I'm gonna do :thumbsup:
i meant loads of peeps have bodged em before now...not grilling you about searching :)
Another "pikey" method of going about doing this would be to
cut all the rust out and treat the area with some Por 15 to stop it rusting again ..
Then you can mould a piece of fibreglass into the battery tray ..
Stevie
Masking tape and paint tbh
Masking tape? That's too pikey, even for me, Tobe! :-D
Strength needed to support the battery.
i used soem thin aluminium sheet,.. as said by everyone else,. cleaned the rust up,.. bent the sheet into place an then pop rivited it in wit some sealer then paint on top sorted!
