Timed intermittent wiper relays
As title really, these are really useful things to have.
When its slightly raining and the intermittent wiper comes on before theres any amount of rain on the window or its not raining enough to have the constant setting on but too fast for intermittent :lol:
I think you get the idea.
To use:
Push the wiper stalk down
Push back up
When the desired amount of time has passed push it back down
The wiper will now remember that time and keep doing it
If you dont need the time setting you just push it down and it does it like normal.
Very good!
£8 Posted
Edited by carver
  • Replies 8
  • Views 470
bumpppppppppppppp
Are these the ones you get off MK3 golfs?
Do you see any reason they wouldn't fit on Sciroccos?
Suppose the real question is: What number relay do you take off to replace with these.
If they'll fit, I'll have two.
Where abouts in Derbys are you?
May be able to pick up and save a trip to the post office.
Yeah these come from mk3 golfs.
The relay number is 99
I'm not sure about it fitting a rocco it probably will but if you take a picture of your relay (pin side) i will have a look at it.
Sorry it's been ages getting back to you... Been really busy...
I'll check the number on the 'rocco... It's not in my posession yet, but I'll be over working on it in the next couple of days, and I'll have a look then.
Cheers.
John.
ok mate no worries
These are well worth having
Free bump, cheers dude
should fit any VW from early eighties on iirc,
its a straight swap for the 19 relay.
i've used em on roccos, polos and wedges.
(later wedges only unless the loom is converted)
^ cheers dude. They are a handy thing to have for long journeys.
