Help with polishing rims
Hi I'm in the process of polishing my rims problem is I'm wondering if this is how it should look after using 2000g wet and dry paper?
Also whats the next step i should take?
  • Replies 26
  • Views 3k
Have you tried any metal polishes on it, There is one that comes in a black and goldy tube...for the life of me I can't remember the name, Autosoul or something? :S
Yes its autosol I've got peek metal polish as reccomended by a few members but cant use it as i dont have a lint free cloth.
I've not long used some brasso metal polish but i can still see some score marks from when I've rubbed it down.
Any other advice
Rub them back with 600 grit and then 800 grit. Then buy a sissal polishing mop and use the brown cutting compound to take out the marks and polish them up..
looks like you have stepped up the stages too early...
How long would you reccomend using each grit of paper for?
until you see none of the lower grits scratches
autosol i'll think your find
just try peek. dont worry if the cloth aint lint free. its never caused me a problem :thumbsup:
have you used WD40 with the 2000 grit???
wet & dry, but do it dry then wet!
Did you go straight to 2000? Looks like you still have marks from using harsher grits you need to remove.
Work up through each grit until you eliminate the marks from the last step. Choose your starting grit depending on the level of corrosion or casting marks you need to remove.
I've got loadsa bits left to do but think I'm going to invest in some mops and compunds, to use on the bench grinder especially. Heard alot of good things about them, in particular reading this and the other articles on the site.
You have to keep sanding with every grade until it stops doing anything. Then move on to the next grade.
Once you get to about 600-800 grit you should start seeing a reflection and hardly any marks in the metal.
I'm lost on as to which grades of paper i should use and in what step e.g what grit first and the next and so on
No but what does the wd40 do? sorry for sounding stupid
My other half spent around 45 mins using 2000g and after a quick polish with brasso metal polish this is what the out come was.
not bad cant see to many scratches left
Problem is you can in person lol
Work through the different grades of paper untill theirs not really any scuffs left should of got a good idea of how to polish before getting halfway through it and asking tbh.
No i kind of have the idea but not to sure on a few things
I would say start at around 400 cause there seems to be pitting/marks in the metal which you need to remove before you can polish them.
You want to go 400 > 600 > 800 > 1200 > polishing mops > wheel sealer.
Then you should end up with a finish more like this
:D
:D
listen to this guy he speaks the truth
polishing wheels is boring and time consuming but when you are done its all worth while
i spent 2 weeks in the garage bringing my kerbed and lacquered peeled bbs wheels up to this standard
once you have sanded use the polishing mops they make a hell of a difference you can use clay aswell to pick up any dirt left on the wheel. I bought the 8pc wheel polishing kit here..
http://www.thepolishingshop.co.uk/acatalog...shing_Kits.html
looks like this..
these are my rims which i was refurbing but lost interest and are still in my garage!!
Edited by tomadomeit
In the link above is a guide to metal polishing :-D
i dont see one? :-(
left hand side 4th from bottom.
can see a link to polishing kits no link to a guide though????
