Drivers Door wont open with key
Hey some little trampy git! broken into my car to steal my 5 yr old sh*tty stereo! ggrrr
They tried to open drivers door lock but couldnt so smashed side window!
Anyway as a result of their tampering, my driver door lock doesnt open from outside with the key. Although it can still be locked from outside?! so I'm opening passanger side door leaning over and pulling pin up to get in!!
is this an easy fix?? can I do it myself or is it a garage job? really dont wanna spend alot of cash already cost me £70 excess for new window :angry:
  • Views 1.4k
i'm assuming that was meant to say 'locked from the inside'? :lol: first thing to do is probably pop down the scrappy an grab a new handle, its easily removed from the inside of the door, you'l find a torx screw inside the door shut, opposite the handle, undo that an slide the handle out
you could try swapping the key barrel from your old handle over to the new one as they've probably fucked the mechanism up
yea change the barrel. If enough force is applied to the barrels on polos they will just spin to stop pikeys brute-forcing the lock!
I got to my car after work, put the key in the lock and nothing! No damage to the lock. The key just turns!!
