golf+ magazine
has anyone got a copy of the golf+ magazine from june? there is a tech article on rebuilding a g-ladder. the second part is in july's issue, but i didnt get the june one and cant find it in the shops, so was wondering if anyone could scan it in?
I can scan the july one in, then maybe would could have it pinned in the engine section as I'm sure it would be a usefull resource.
  • Replies 16
  • Views 2k
sounds good to me mate... :thumbsup: i'll get looking at lunch...
Sounds useful for defo mate, i'll check my local shop, hopefully they'll still have it in.
Just found out you can get online back issues, if anyones willing to purchase it for 3 dollars you MIGHT be able to copy and paste the needed parts out of it. Maybe one of the moderater guys could doing it using members money for the use of the club?
I say might as these things could have a copyright on them.
Hope these help!
Ok, scrap my idea, that was a lot easyier lol
id add to that - heating casings up to remove bearings a lot easier!
Anyone know where the best place to get a scrap G-lader is? As I do that sort of thing all day long at work and wouldn't mind giving a g-lader a go.
Far more simple inside than I was led to believe.
edit: came across a bit wrong... obviously they aren't simple simple, but as I said I wouldn't mind having a go to see how hard it is.
Edited by tobyk
when putting it back together put the bearings in a sealable air tight bag and put them in the freezer for a few hours, coupled with the heated casings they should slot in nicely :thumbsup:
what? a post from modest with helpful tips? wheres the sarcasm and humour gone?
very true.. i use my oven about 120degrees they just pop in.
and the counter shaft - i prep that and add it as one unit from the freezer
any tips on removing the oil seals? or is it vital to have an oil seal puller?
tobyk Posted Yesterday - 7:55pm
Try ebay mate, lots of shit on there lol I might be wrong but If the scrolls get badly damaged are they not totally written off basically, I remeber seeing somewhere one being sold but it was said that i think pitstop developments had repaired one the scrolls. I dont know about to what extent they can do this to though.
Edited by drewbar
oil seal puller are essential - they pop out quickly too and can easily damage the walls
scroll repair usually only happens with very minor repairs!
cheers pete! is there any other specialist tools required other than a set of circlip pliers?
sidecutting pliers for the woodruff key
circlip pliers internal and external
seal puller (mine is modded so only has a pull one side (i.e. is L shaped not T shaped if that makes sense)
pete
ps - pointles splug for clubg40 forum for all your g40 questions
