1.3 mk 3 Heads
Hi All,
Urgently needed, due to mis-calculation. :roll::paranoid:
1.3 mk 3 Single Point Injection Heads - Polo or Golf
Kentish area if possible
Any help would be much appreciated
Thanks Dave
Edited by racer527
  • Views 689
all mk3 polo heads are the same!
The 1.3 head has bigger inlet ports then the 1.0.
I am using a 1.4 aex engine in race car, but we have to run a carb. I thought that a carb manifold would fit the aex head but it don't. :thumbsdown: But a 1.3 head fits, which allows me to use the carbed mainfold, and the single point injection cam has a higer lift then a carbed cam.
Thanks Dave
Anybody :-D
Can I just say... I think you may find that using a 1.3 head (which is flat) may increase your compression in to silly figures because I *think* the Mk4 Polo engines have a small combustion chamber in the head. The best cam would be the GT/3F cam.
You may have to swap your entire engine out if you want to run a carb or modify your existing inlet manifold.
