mk4 boot smoothing
I'm smoothing a mk4 boot, just the badge and the handle.
the badge has already been done just needs sanding down abit and a new layer of filler on top...
as for the handle, what is the best way to smooth that?
I've been told to put some filler on the lip, then put a metal plate onto the lip so it fills it, then skim over it with abit of filler.
has anyone done this before DIY style?
if so how did you do it...
Cheeers. Mike.
  • Views 1.2k
take the hadle out and you will be left with a small recess weld a plate in that and then a skim of fibreglass and a final skim of filler, no other decent way of doing it really, i guess you could rivet some steel into the hole but not sure that will be very strong and may crack after you have shut the boot a few times.
weld in a plate then fill with minimal filler to avoid cacking
I've spoke to a guy i know who does welding, and he said it will be quite hard to weld a peice in the handle bit, because its only thin metal.
shouldnt be any harder than normal just set the welder low and go easy on it
ye as will sasi, its only bodywork afterall:-? and as I've been welding up hole sin ma mini I'm sure it wont be much harder than that!
