Basic Wash Method - A Guide
Now i know there's already a link or two floating around to various websites containing guides, but i didn't see them until after i'd washed my car especially for you lot. So what the hell i'll write the guide anyway.
Now i'm an immigrant on here from detailingworld.co.uk, but i do drive a polo so i'm here for a reason, but i might as well start making myself look useful, so here's the first of hopefully a few guides i'm prepared to write up for you lot.
Its basically called the Two Bucket Method, or TBM for short. The principle being that instead of using a bucket, sponge and some fairy liquid, you actually look after your paintwork. Two buckets are used, one a mix of water and your chosen shampoo, of which i will reccomend a few of my own personal choices, and the other just plain water. Also, a lambswool wash mitt is used, for reasons that will become apparent in a second. The buckets also could contain a grit guard, basically a mesh grille thats slightly raised from the bottom of the rinse bucket. It will trap the grit removed from your paint during the washing procedure, stopping you from rubbing it against your paint and scratching it. The wash mitt is used in partnership with that, because it picks up grit and traps them in its long fibres, where as a sponge has no where for the grit to go, so its being rubbed between the sponge and your paint. not good.
So the wash process is as follows,
Two Buckets
-One shampoo and water
-One pure water
Lambswool Wash Mitt
Drying aid of some kind, preferably a drying towel.
You dip your mitt into the shampoo mix, and working from the top of the car downwards, your move your hand in straight lines. Not circular, as this also creates swirl marks.
I also prefer to pre soak the car using a foam lance, an attachment to my karcher pressure washer, that covers the car in a shaving foam like coat which helps remove grit and guff before i wash.
My nice and dirty Polo
My Foam Lance attachment, filled with Super Snow Foam mix. Not strictly necessary, but bugger me its fun to piss about with.
And this gives the followeing results:
Left to dwell for approx. 5minutes, gives me time to nip in and fill my two buckets with warm water (yes i am a tart) and select my shampoo.
The said buckets, light bucket is for the rinse.
And after washing using the TBM Method
This was then dried off using a large waffle weave drying towel, instead of a chamois or water blade. I just prefer using it.
So there you go. I apologise for missing photo's out of me in action, it would probably be of more benefit, so i will try and take some on sunday when i next give her a wash.
So onto reccomended products:
Washmitts, as far as they are concerned, they needn't cost you the earth, i think mine cost me about a fiver from halfords, its lasted me a year and has finally split, but its still useable.
Shampoo, I've tried Meguiars Gold class, and next, both are average, they do the job but the finish left behind isn't amazing. The shampoo used in this tutorial was Zymol Autowash, costs a fiver from halfords and is bloody fantastic. I've just bought some new items to try so will update this as necessary.
Also, this guide was for bodywork only. not wheels.
Wheels must be done before the bodywork, or you risk splattering your freshly cleaned paintwork with brakedust, which makes a hell of a mess and can be a right bitch to remove. This will be covered in a sepereate guide, or added onto this one, just as soon as i find my poxy wheel brush.
Right, i won't bore you any further, until the next time
Ed.
  • Replies 12
  • Views 1.3k
Bump.
Just to add, i'll be more than happy to try and help out with anybody's car washing queries, if you need any advice as to what products to go for be it within a budget or not i'll put forward my suggestions. Any problems at all, give me a shout.
whats the best polish and wax for a black car???
What sort of price are you looking to pay?
Whatever it takes to get a good finish that will last. Just bought a polisher, did the worst swirl marks with farecla extra fine (G10 I think) then did whole car with mirka polar shine, then whole car in merr polish but I've been told I need to wax it ? P.S. not polo in avatar obviously, Honda Civic.
Edited by well-abused-5-door
I personally would ditch the merr polish, not heard a good thing about it, but if you are happy then we'll leave be. If you have a machine polisher, whichever one that may be, i would reccomend trying some carlack 68 sealant, with a couple of layers of collinite 478? wax over the top, will be extremely durable, and give a nice wet look shine. Will probably set you back about £30 for both i think.
Alternatively, Dodo Juice purple haze, or swissvax onyx both work very well on black paints as wax, and use Chemical Guys Jetseal 109 as a sealant, applied by machine, give a couple of layers, its to die for. But this option is more expensive, probably around £60
Hope this helps buddy
Ed.
Cheers great info I'll see if I can source some of them. :-p
Polisher is a kestrel, sort of like an angle grinder but vario speed they had it on special at local body shop £50 and threw in spare brushes and farecla pad so I could'nt resist. :shock:
whats the best way to get a good finish on a pistachio green mk4, its average condition with swirl marks ect
i tend to just rinse, then turtle shampoo it, then rinse then foam it then rinse then wax it and rub that in by hand it looks ok but takes a while and doesnt last for long
Try online shops such as cleanyourcar.co.uk, elitecarcare.co.uk, carwashnwax.co.uk, i've never had issues before with any of them. Not heard of a kestrel polisher, but it obviously works well! Perhaps try getting some new pads for it if possible, maybe a finishing pad of some kind, that would be a good option to help you apply a sealant or a wax, you'd get a more even coat than if you applied it by hand.
Ed.
also can you reccomend any cheap electric polishers
To get it absolutely spot on, you'd be looking at spending quite a bit of money. To get rid of the swirl marks properly requires a machine polisher of some description, and then the relevant polishes and pads to suit. To be honest, your looking at about £190-£200 for a starter pack, enough to rid you of most of the defects on the paint. Then you'd want a good shampoo (zymol autowash from halfords would do you proud), and a good Last Step Product (LSP) perhaps Dodo Juice Rainforest Rub? Designed specifically for green paint. About £30 a tub though so not exactly cheap.
If you were looking to do it on a tight budget, then you won't go far wrong with some Zymol Autowash, Autoglym Super Resin Polish (this will fill some of the lesser swirls, reducing the amount you can see) and it will also give a good shine, then top it with some Collinite wax, would be extremely durable and you could probably get it all for £40?
Microfibre towels will also be required, but you can pick packs of them up from halfords for not a lot of cash, they're much better for removing wax and polish, much better than a normal rag.
Its also worth mentioning that the car would most likely need claying, in which case meguiars do a smooth surface clay kit from halfords, i think mine cost me £22 or something, but you get clay, lubricant, a nice big microfibre towel and some cleaner wax as a test product. The clay is designed to remove all the guff that shampooing doesn't, e.g. tar, tree sap, industrial fall out.
Claying will be the next guide i put up here.
Hope that helps.
Edited by edthedrummer
awesome niceone, i think ill go down the claying route and get some of the cheaper products you said and borrow a mates polisher :D
i do use microfibre towels there awesome and i have a sheepy mit which feels awesome :p
Ahh i didn't think of that option! yes go for it, if you can borrow a polisher off a mate that would be a big big bonus, saves you spunking all the money on one only to use it the once.
