my new project golf GTD.
hahahaha, your still a mad mofo dude, what you doing with the kr/
gonna sell it on to fund the coil overs and wheels once this is on the road, just a shame about the scratch down the side and the cracked filler under the rear light, could of been worth a good bit otherwise as its only got 92k on the clock :-(
  • Replies 84
  • Views 12k
Modest, you are indeed mad as a hatter! Will we be seeing Guys nonce mobile mk2 at the polo show and will it be putting on a ploughing display for all us yokels?
thanks :-D
and yes the GTD should be at the polo show, and i'm trying to get this lower than the last (looking in to ways to higher the engine more for more clearance :lol: ). so yes snow plough should be in full effect 8-)
new wheels sourced and being collected tomorrow 8-)
Edited by modest mouse
thanks :-D
:shock::shock: MAD MAD MAN! what you going to do about lower arms, you last ones were about 10 mm of the floor anyway :lol: meh, at least you aint pussyin out and going for bags 8-)
i think they maybe the deciding factor of how low i can go, not sure i can go much lower (if any) than the old mk2, but the problem with this is the sump is at the same kinda height as the sub frame (on the old 1.3 it was tucked up well out of harms way). so i'm thinking of lifting the engine on some form of spacers, then fitting a sump guard for good measure. as pointed out by the main man tobyk, this would also make the angle of the drive shafts a little less extreme relieving some pressure off the cv joints.
hmm ye see where your coming form with that one, and I'm guessing modding the lower arm mount point s is abit drastic just to go a tad lower.
I'm not sure i woudl be happmy lifting the engine much would you be using alloy lifting brackets as it will vibrate like hell if you do with it being a burner. small brackets and std mounts ontop could well work, jesus all this for a bloody diesel :lol:
i've not looked into it that much at the min tbh, gotta get it in the car first and then use some trial and error.
if its a steel sump there was a thread i remember reading ages ago about a mk1 golf man in the states who very slightly made his sump shallower.
He chopped a section out of it and welded it back up, ok he wasent using the car that much but i cant see why that cant be done? if its only a small section it cant be that bad??
i'll have to look into that mate, sounds like it maybe an option :thumbsup:
i'll bring some planks of wood then, just incase you encounter some roadkill or a pebble on the road! lmao.
got my new wheels today so trial fitted them on the 16v, behold the girth...
they do stick out a bit, BUT the fronts had a 10mm spacer on to clear the calipers (don't think that will be needed on the GTD), and the rear axle on this is out of alinement (the other side has a 10mm spacer on it just to bring it some where near level with this side).
although after fitting these i now know this car is not going to be as low as my old mk2 which has gutted me, but the fact they look so good kinda makes up for it.
btw the fronts are 13x8's and the rears are 13x9's 8-)
Did you buy them off some kid with a yellow lupo?
I love my GTd! Its off the road at the moment until i sell my G40! Needs a bit of welding and some other bits and pieces! Matt off here just bought a metallic blue j reg one for £700 with 200K on it and a tank full of bio-diesel!
the offset looks well out ,but hey if thats what your into good on you!
Indeed, he went to Northampton earlier today.
yeah thats the chap, seemed like a sound lad, nasty pot hole at the top of his street tho, nearly ripped my wish bone off :disgust:
got them for a steal tho so i'm happy.
i saw the post about the rot in your boot on edition, glad your sorting it tho cause its a mint colour :thumbsup:
as said in the post, the offsets will look more out on that due to the spacer and the misaligned axle, but yeah they do stick out a good bit, but hay hoe its a small price to pay for that kinda dish imo :lol:
Can't remember if G60 rear arch trims are wider than 16v ones or not but thats somewhere to look if you want to stick close to legal.
That looks spot on. I think it would look worse with lower profile tyres, they actually fill the arches like that.
i think the G60 arches are a little wider than these ones, i'll have to look in to how much they are tho, i'm not really looking to spend much on this, more of a quick budget project).
i was thinking of putting some 175/55' (i think that was the size any way) that i had on my old power techs on the 8's so theres a little less tire on the front and it'll give it a bit of a raked look., but i'll come to that when i come to it tbh, no great rush at the min.
looks like curries old blob now, and it is a proper chode now, low and fat. something just doesnt look right, front could be a bit lower, or the back raised slightly.
g60 arches are mahoosive but wont cover those, jag r types have like plastic spats that are just flat around the arch lip and cover the tread of the wheel, just make some pikey awning for each wheel and jobs a good un
saf you nobber do you even bother reading threads? :lol:
i was just trying them on my 16v for size and to give me an idea of how far they will stick out. when they go on the other one it will be running coilovers so i can get it sitting right. and as said in 2 of my other posts above, the wheels stick out further on this than they will on the GTD, so G60 arches might do the trick.
mwahahaha not when its before midday 8-)
I'm well confused with what the fook your up to anyway, the wheels are going on the gtd/ arent you sticking the gtd in that shell?
the weeks are rude as a mofo, what does the missus think of it? and stella inc garages for the win.
i reckon ill be down nuneaton way next month at some point so ill give you a shout
Saf - peado
Guy - peado finger
Them wheels are wider than a fat lady lying down!!
Cool.
