Headlight Steamed Up
is there any way to sort a steamed up headlight? :lol: theres no holes/cracks in the lense. there steamed up because i tried to clean them out :lol:
would i have to seperate the glass?
if so how do you do this? and how do you seal it again?
at a wild guess couldnt you just blast in a hair dryer to get rid of the moisture and then get a stick with some tissue taped to the end and give it a squirt of glass cleaner and then make sure the seal where the bulb holder sits is tight
Stick them in the oven!
i tried the hair dryer and they steamed up again last night :lol:
I've heard this about the oven. but how long do you put it in there for? what gas mark/temp? and what would go nice with it?
If you're going to use the hairdryer, then take it off the car, and hold it with the back pointing upwards to allow the water to escape out of the headlight through evaporation. Then use a bit of tissue to wipe it out to make sure you've got rid of all the water. leave it to dry overnight, check all seals, then refit. It should be OK then. If it continues to steam up, then you have a leak or a broken seal somewhere.
