removed bump strips....oh dear
So i removed them as carefully as i could, but it still seems a layer or two of laquer has come off, although i cant tell if the laquer or actually paint has been stripped. Anyhow the paint is obviously a different shade of the rest of the car. i am also left with the outlines of where the bumpstrips used to be (this is not outline by the glue, but by the removed paint/laquer)
so basically, best way to get rid of colour change and outlines? somebody on here must have had this problem aswell, what did you do?
Edited by xb0vv
  • Replies 14
  • Views 1.7k
mine just left the glue behind and i used a buffer 2 get it of is the paint duller were the bumper strips came of
it might of been resprayed, if they are bad its respray time unfortunatly.
no i had this problem to its a lighter paint underthe bumber strip all i did was sanded it down to get rid of the out line and resprayed it
put them back on. lol
  • 1 year later...
I have this with my rear badges lol.....the boot is a little faded so it still says 1.4cl polo :lol:
Time to get the t-cut out i think
i had this problem also,
sanded it down and sprayed over it but you still can see it pretty bad,
time for a respray i think
i had this problem i just painted the door :(
I had the same problem pal.
I only took one side off and realised it.
I used petrol to get the glue off works a treat and gets rid of the out line slightly making it less noticeable.
Personally i dont think t cut will do the job. as people have said above a respray is in order or you can just put em back on.
I know once I sorted my doors out I will be resprayin em!
T-cut and elbow greese!
put em back on or book it in for those panels to be repainted
Go over it in 1200 or 1500 grit and get some decent abrasive polish and you might get away with it.
I had the same problem with mine when i first removed them. all i did was sand down the parts where the bump strips were with some 2000 whet an dry and buffed it with some g3 came up a treat
Hope this helps
Count yourself lucky mate, i took mine off to find holes in the door!
hmmm.... bad times!
